While working with a customer on a Pepwave MAX BR1, we found that the WiFi WAN connection was showing up differently than the other WAN connections and it also could not be moved to a different priority than 1.
We discovered that the setting found under the WAN “Details” (for any WAN interface) labeled “Independent from Backup WANs” was the cause and simply disabling the setting fixed it.
