I did just install my on-premise Incontrol2 VM.
The devices can be added, but the address-search does not work. If I enter an address, the GPS-coordinates for my balance-routers is not updated.
I can only see:
The Location field may not correspond to the address
I tried to insert a google-maps-api-key, but the problem still persists.
No, I do not see any suggestion.
If I do only search for one city (e.g. Amsterdam), everything is working fine, but if I search for an address, nothing happens and the warning-sign comes up.
→ Amsterdam, working
→ Amsterdam, Zandstraat → warning sign.
We just identified a bug in passing the API key to the Google Maps API service. We have applied a hot patch to your system. However, we find another issue. On the Google API console, you enabled HTTP referrer restriction on your Google Maps API key, which is good. But your ICA’s address is not on the accept list. Please input your ICA’s URL prefix to the accept list.
We will release an ICA update to address the issue.
The maps are shown correct, but the search is still not in function.
I choose the device, edit, type the address, but do not get any suggestion or a result.
After further investigation, I find ICA customers also have to enable the Geocoding API in the Google API console. After enabling it, the address lookup is working now. We will update the setup guide in this aspect.
You hit a known issue with 2.7.3 which has been addressed in 2.7.3.2. After the IC VM was restarted 2 days ago, the Google Maps API key was not properly applied. We remote logged in to your ICA via RA and applied patched. The problem should have already been fixed.
