Hello. I’m a drop confused about Incontrol2 ports needed to work with my peplink Balance router.
Do I have to allow open up certain ports (and perhaps port-forward them) to allow the peplink router to receive commands from the outside, or does the peplink establish these connections outbound?
I would think the latter, since not everyone has fixed IP addresses, but just wanted to make sure. Also, I’ve seen several ports listed on various posts, so wanted to know the absolute minimum needed to be sure they are “open”. Finally, how can I test from a computer running on the LAN network the accessibility of the incontrol2 cloud?
Thanks in advance.
