Hi support,
Please help to check on the possibility of enabling the notification when there is the changes of the cellular network.
For example, the end user will get notified when the cellular change from 5G to LTE or vice versa.
Thanks!
Hi support,
Thanks!
+1 on the feature request.
I am wondering if, for your use case, the PLMN alert could work in the interim? Of course, the Carrier would need to use different PLMN MNC’s for 4G vs 5G and not all do…
id really like to see this also please
