How do I update the SURF SOHO to show its new physical location after moving it to new location. It still shows old physical location
Hi @Grovepark
I’m assuming you’re looking to adjust the location that’s being shown in InControl2.
Since the Soho doesn’t have a GPS antenna, you can update the location manually.
In Incontrol2, go to the device level and click on the edit link in the upper left above the router model, serial number and name.
You’ll get an option there to give the router a location using an address or GPS coordinates.
EXCELLENT SUPPORT. That’s exactly what I was looking for
Respectfully
James Smelser
