Been fighting with InControl2 False Offline alert since my day 1 on it.
Still have not been resolved.
Keep opening tickets but no luck, is it just me or some one else seeing this?
Examples:
Date: Thu, 27 Mar 2014 15:04:46 +0000
To: [email]
Subject: Offline alert: 1 device in Indy
1 device offline for more than 60 minutes at 2014-03-27 11:04Z20_3GWRiverside (2830-E0C8-8D3A) - “Pepwave Surf SOHO”
-------------------END OF THE EMAIL
And device currently online, and it was down only for few seconds.
Here is report and it matches DATA from our monitoring system: Online / Offline History [TABLE=“class: display table table-bordered, width: 100%”]
[TH]Offline Time[/TH]
[TH]Online Time[/TH]
[TH]Duration[/TH]
Thu, Mar 27 10:04:10
Thu, Mar 27 10:04:33
a few seconds
[/TABLE]
But I received Email alert was sent first that device was offline longer then 10 minutes, now see above offline more then 60 minutes.
little bit annoying then you have almost 100 devices.
Yes, I’ve been receiving many false notifications. The systems connected to our PepWave MAX-BR1’s have a 30 second heartbeat that hasn’t gone down when inControl is indicating they are down.
We also see the system was sending out some false alarms out last week. In the weekend, we identified the cause and have applied some fixes. So we see the system should have stopped sending out false alarms since Saturday. We will keep monitoring the system closely to avoid the similar problem from happening again.
Our PDX LTEA started throwing “SIM card switch over alert: " errors after upgrading to 8.2.0 build 5305. There are no SIM cards installed which is what you see on the InControl screen but when you drill into each card slot via remote web admin you see: (SIM Card Detected) for the A slot and (SIM Card Detected) (In Use) for the B slot. There are no and have been no SIM cards installed in this for quite some time. The device throws alerts as it cycles thru all 4 SIM modules. There’s nothing to :switch over” to because there are no cards. How do we clear these alerts?
