As a heavy user of InControl2, I wanted to make it a bit more friendly to the eyes. I built a Chrome and Firefox extension to add dark mode and a few other handy features.
Set dark mode, light mode, or system
Enable default table size increase (groups/lists) from 25 to 100 or more
Show/Hide “PrimeCare is Expiring”-style messages on lists
But, the biggest:
GLOBAL SEARCH. Control+K / Command+K will bring up a modal allowing you to search and navigate to orgs, devices, and groups across your entire InControl2 login with a single click:
Any way you could get it to support ICVA/custom domains? Works wonders on our public IC but as the domain of our ICVA is not supported, I’m not able to get it to work on Firefox.
Just checking, but were you using the Firefox Add-on and did you ensure it was enabled in the add-on settings?
ICVA is easy but also complex. It would require us to list all domain names in the approved permissions which would subsequently expose your ICVA domains to anyone else that used it. We’re happy to put your ICVA domain names in the extension if you’re OK with that, but I strongly recommend against it.
Tell it to run on every domain (obviously not great)
If we took the latter option it would mean more scrutiny and requirements for submission to the Chrome and Mozilla extension stores and, since this is a free extension, we opted not to do that.
Hey everyone! I’ve been making updates over the past several days. I just submitted v0.5.10 to Google and Mozilla and they will require you to re-enable permissions as we have added a new host pattern.
As always, let me know if there are issues or recommendations!
@ChristopherSpitler - great job. Small feature request for the CTRL + K search function. When you type in the name of the device, it currently shows a list of names and you can click on then. However, there’s no way to right click on the names to open multiple devices, you can only click and open one at a time. If you could add the right click feature to that list, that would be awesome!!!
