Is there any way to generate a report that contains signal strength from inControl2?
We have over 500 MAX-BR1 units deployed and find it very difficult to find out which units have cellular signal strength problems without manually looking at each unit within inControl2.
Is there any way to add signal strength as a column so we could sort units from weakest to strongest.
That’s one of the biggest features I miss using inControl2 instead of Cradlepoint ECM.
Also really need an easy way to know which units are in a failover state from WAN to cellular without looking at each unit’s details.
Is there any kind of a third party solution?
Thanks!
