hi again…
is there any way to copy a SSID setup (all the configuration, with the CP values/variables) from an SSID in a group to another one? or, alternatively, an import/export feature?
let’s say I have customized the splash page (colors, translations etc)… I’d like not to reinsert everything everytime I create a SSID for a different group of devices.
any hint?
We have a plan to take the captive portal settings into a separate page such that you could maintain a list of captive portals. On the SSID Settings screen, you could apply a captive portal to an SSID. So you will be able to define a captive portal once and apply it to different SSIDs. Do you think it will solve your problem?
yes, sure, it would be great
thank you
