InControl login
I can login to InControl ok on my laptop using Edge or Mozilla. However, on my desktop at home, after entering credentials the page doesn’t load and keeps trying over and over but to no avail.
Is there some kind of security setting in the browser that needs to be changed, or is it something eles?
Any help is appreciated,
Thank you.
You could try and open an incognito tab.
If that helps you will need to clear your browser data. Maybe just cookies is enough.
Hope this helps :slight_smile:
