I am using 2 fusionhub hosted in Amazon EC2, due to elastic IP and NAT 1:1,
InControl is not able to establish a connection between my two FusionHub, it could have worked if one FusionHub did not rely on nat 1:1 for its wan.
As a result I have to setup a PtP tunnel manually via the local web admin of my FusionHubs.
Could InControl detect this and do the same I do when I set the tunnel manually?
Wouldn’t it be convenient to have the ability to set the WAN IP address to be used by speedfusion? Maybe in FusionHub WAN settings?, nor to be able to edit the connection in details via InControl?
Florent
