Is there any way to pull IMEI reports from Incontrol? I have zero use for IMSI.
What do you need the report for? ie what data do you actually need to report on?
If its just IMEI against device name or active SIM ICCID you can go to Settings > Device Management at a group or organisation level and pull a CSV file that will show all your device IMEI’s and the current in use ICCIDs.
That what you need?
