InControl Data Extraction
Hi There, is there an API (maybe REST API) I could use to extract data directly from InControl or equivalent? I don’t want to query the devices directly, I am hoping I can just get the data that is already aggregated
  • looking to get SNR, Signal Strength, etc.
Hi Damian, yes there is. You can find the live IC2 API documentation here: https://www.peplink.com/ic2-api-doc/
