InControl config differences
Restoring/applying/downloading a config in InControl is very easy and convenient. However, seeing the differences between twon configs is impossible. This makes debugging very hard.
What possibilities are there to compare two configs for e.g. switches? Are there any plans to improve configuration history differences?
thanks!
I hated managing Netscaler appliances, but the config diff between running and any saved config or between 2 saved configs was easily my favorite feature they had. F5 offers similar through their online portal but having it on-appliance when you’re in the thick of it is best.
