As a new customer to Peplink, it would be nice to see the Bulk Configurator improved.
- We need to be able to create templates directly in InControl
- Have the ability to edit a configuration file in order to create templates
- View/Edit/Commit changes before loading the config file to Bulk Configurator
Having to create the config file on a physical device is very cumbersome and time consuming.
+1 Not always having a “golden” device ready to make changes and export them can be a pain
It would also be nice if we could have a way to prepare configuration for the various Ic2 managed config without needing a device in the group to enable it, i.e. cannot configure SSIDs and so on without putting a device in the group that is capable of providing Wi-Fi.
Something I’d love in Ic2 would be the ability to create dummy devices that can have configuration assigned against them and then a serial number from a real device attached later down the road.
For example, add some switches and APs to a group and configure all the SSIDs, radio settings and ports as I’d like them to be and then once the serial numbers are available work through and assign them to each dummy device.
+1 for that this feature!!!
Would be epic to have the ability to create settings and configurations before devices are added or have a setting that enables this in a group if no devices are present yet. Having it on by default, no, but with a setting to enable configuration before a device is added would be very useful.
