Hi
I have registered the AP One under InControl2, and want to configure the “Web Portal Login” feature. The GUI prompt me to use InControl; but I can’t use the same serial number to register (seems it is registered under InControl2). But I can’t find any Web Portal Login setting under InControl2. Pls advise how to configure it.
How many users account that I can create for Portal Login under InControl2 (or InControl)?
For AP One connect to Internet through a Firewall, which port that I need to open in Firewall so that InControl2 can manage the AP One.
Thank you for the inquiry. Unfortunately you’re not able to enable Captive Portal through IC2 currently and would need to configure in the Peplink AP Controller. Captive Portal Functionality
will be added to IC2 very soon, tentatively scheduled for early January for it’s release.
