So I added a Pepwave MAX BR1 LTE device to InControl 2 about 2 days ago. I have setup queries for Organization, Groups and bandwidth which all works fine. But when I query for the cellular signals, the CSV has only the column titles but no records. I can read the signal levels on the web site so why are there no cellular signals in the CSV file? Is it because the device has not been active very long? Is there any additional setup required to capture this information?
I think you’re referring to the API /rest/o/{organization_id}/g/{group_id}/d/{device_id}/wan_signals/csv . Please make sure your device is running firmware 6.3 or above. Firmware prior to 6.3 does not support to report the device’s cellular WAN signal to IC2.
Since you can set a start and stop date, is there a limit to the number of records that this can return in a single call? Lets say I wanted hourly records over 2 years. Is that even possible with a single call?
