I have 2 wans and I’d like to setup my connections so that I can access the internal network (http, ssh etc) via either wan simultaneously. I don’t necessarily need to do any kind of load balancing on the incoming traffic, I just need availability.
I have this working on a Netgear FV336. Can the Balance One do this?
The Balance One does have a built in PPTP server that you can connect to, to essentially be apart of the LAN network to access internal devices.
You will need to ensure that both WANs on the Balance are public.
Here is a KB article that will explain step-by-step to set this up:
If you just need straight WAN access from both connections to your internal devices then you would just set up port forwarding rules, this is no problem…
