I have Win 2008 RRAS VPN server and clients using dyndns address to connect to VPN server. Is it possible to load ballance incomming VPN connections on two wan links using one dyndns address (eg. vpn.dyndns.org) or something similar
In order for proper inbound load balancing to work, the domains DNS records need to be hosted on the Peplink. I recommend to get your own domain name/static IP’s and then set up the Authoritative DNS feature of the Balance 210 or higher.
Tim
