I wanted to ask if inbound load balancing on Models 210 and above will work with a software PBX? If I have two ISPs with two different IP addresses, will the Balance router be able to provide inbound load balancing to the PBX server behind that balance router? The PBX to use would be 3CX or FreePBX.
In summary, is inbound load balancing compatible with a PBX Server?
Thanks!
