People;
I have a “balance 30” and need configure “Inbound service” in por 491 (goGlobal) to server 192.168.0.6 in the network, but this not working !!!
I make configs like Peplink | Pepwave - Forum
But still not working !! my network is “NAT”
… in my older gateway (linux) the iptables line is that : “$IPT -t nat -A PREROUTING -i eth1 -p tcp --dport 491 -j DNAT --to-dest 192.168.0.6”
Roberto
This should be a pretty straightforward setup. Do we have everything properly configured under Network > Servers and Network > Services?
Also what is Peplink LAN port IP and subnet? Are we using Peplink DHCP server?
Tks, for your reply
Peplink lan port is 192.168.0.150 (255.255.255.0)
I do not use DHCP form Peplink … i use my DHCP server (Debian Linux)
And peplink config is this
Roberto
Looks right to me. Could you please download a diagnostic report and send it us to at http://www.peplink.com/contact/support/? We will take a closer look at it. Thanks.
Thank you my friend;
But I’ve solved that problem by opening these ports on firewall, which I believed that it was not necessary … but work now !!!
Roberto
Thanks Roberto, I thought we had the port allowed on the firewall
Got to keep this in mind. Now, enjoy!
What can I do with a peplink modem?
It’s a MetroFi Peplink Modem
