Hello Guys,
it’s my first time to work with load balancing and Peplink.
we have purchased a peplink appliance to load balance the inbound access to a web server (3 router with 2 static IP & 1 dhcp), and need plz some information to how implement this in the right way.
1 -please in the perplink wans interfaces when we launch the setup wizard, which adresses’s should I supply? the static public IP or just the private in the same subnet to the router, knowning that i’ll use the drop in mode in the wan2 interface?
2- in the users guides i’ve read that we should make a DNS delegation. So i should add this NS & A record to our DNS server
www NS wan1balance
www NS wan2balance
wan1balance A IPstatic1
wan2balance A IPstatic2
and add a A record in my peplink company.com ipadresse ?
3 - for the DHCP ISP can it be also used for inbound LB ?
4 - we want also use the Bypass Port wich will be connected directly to the web server, if the peplink gets down the DNS replay will still working?
Thank you very much in advance, any useful information is welcome.
Best regards.
