Camera connects to 2.4 GHz, with WPA or WPA2 security. Using Starlink for internet. Camera worked fine when using Starlink router. Will not connect to Pepwave. Chatbox on Eufy site suggested checking to see if port 8.8.8.8 and 8.8.4.4 in your router have not been disabled. Not sure how to do this? Any other suggestions appreciated. Broadcast SSID box is checked. VLAN - Untagged LAN. Schedule - Always on
Solved - turned off Layer 2 Isolation
