In touch action over a remote device
Hi all,
I’m trying to connect to a remote device from National Intsruments that runs a Silverlight app, for this I use the InTouch action from Incontrol2 but I get this error:
“NI has detected that your browser might be blocking a plug-in. Visit Using Info Codes - NI and enter the following Info Code for more information: BlockedPlugin”
How can I solve it? Is it possible to run a SIlverlight app from InControl2?
Hi!
MS Silverlight hasn’t had any development for over 6 years and modern Web browsers no longer support it, I wouldn’t be surprised if there would be compatibility issues. Though your provided link lists some troubleshooting steps that can be done on the Web Server itself.
Theoretically you could also configure a VNC or RDP connection to another host on the network via InTouch, then reaching the Silverlight app via it.
