I have a MAX-HD4 I need to swap out with its RMA’d sibling. The HD4 is currently participant in a PEPVPN and is mostly managed via incontrol2.
Is there a documented process to swap it out with a replacement without losing configs?
Download from IC2 the last file config.
Then upload the config to new Hd4 , remove the old HD4 and active the new HD4, so the new device have the old config of HD4 in fault .
Finally register the Hd4 on your IC2 .
Thank you, this worked perfectly. I had to delete the device completely in IC2 and load it back in.
very well ![]()
Don’t forget you will need to change the serial numbers in the PepVPN profile of the device at the other end of the tunnels. You can add multiple serial numbers so that you don’t need to change the profile again once your device is returned.
