Is there a way to use SNMP v3 in ICVA to send or pull GPS data of MAX routers to another application?
I have the Peplink router API documention, is there specific API documentation for ICVA?
ICVA having similar API for IC2.
https://www.peplink.com/ic2-api-doc/
Check the user guide below on how to access API for your ICVA:
