In IC2, has anyone seen a Peplink cycle from online green to yellow, just back and forth every minute?
I’m staging 3 new Peplinks behind an existing deployed unit, and all three of them are doing this. If I were at the customer site, I would try connecting them directly to the ISP modem to see if that fixes things. It sounds like a communication issue between IC2 and the devices. I feel like I’ve seen this before and fixed it, but I can’t recall the solution. Instead of me driving out to the site to figure this out, does anyone have any ideas?
I’ve seen this, it seems like database replication being slow through the VIP/proxy for primary IC2 access.
However, do note that if you’re staging Peplinks behind other Peplinks, the devices cannot handle two similary-numbered subnets on different interfaces cleanly. You will need to change the primary/internet-supplying router subnet to something other than 192.168.50.x.
Thanks for the suggestion Christopher. It turned out to be something funky with the ISP. I later noticed the main Peplink was also experiencing it. I rebooted the ISP and all is fine. And yes, main routers subnet was something different than the other models.
Those pesky ISPs! Glad you got it sorted
