Ic2 - SIM Pool - Roaming Data Allowance
Is there a way to have Ic2 track a SIMs data use for both domestic and roaming use separately?
We have a bunch of Pepwave devices that regularly travel outside of their home country and have different monthly data caps on the SIMs depending on whether domestic use or roaming use.
It would be useful for us if Ic2 could track the usage according to whether the device is roaming or not, ideally with some sort of toggle per SIM to enable this separate tracking (to complicate matters we have SIMs that are used exclusively within their home country but they are fancy ones that roam across any available network, they do this by essentially being provisioned as overseas SIMs and thus are always “roaming”).
I can only support this request. In Belgium, you are always very close to a border. We use data SIM cards with a different allowance for domestic and EU roaming data. We have to monitor both, and get notified when either one of both those allowances is almost reached.
Was there any news or uptake regarding this request?
Thanks!
Is there any news on this?
