IC2 DB Replication Problem?
Over the past few weeks, after making changes to a device (we’re on Mars), I’m seeing flapping of telemetry on IC2.
For example, if we have a B One 5G, and we use the wifi slider to turn wifi OFF on the device page in IC2, it will flip back and forth between OFF and ON for several minutes. This is true with WAN status, device status (green/orange), and other settings.
It seems that there may be a database replication issue, or something similar causing split-brain routing, etc.
thoughts?
Hi Chris, could you please create a ticket with the device details, engineering would like to investigate the issue. Thanks
