IC2 Appliance for KVM/Xen
Hi!
I am using the IC2 virtual On-Prem appliance (and I like it), but currently, it is only available vor HyperV and VMWare.
Is it possible to run it on other hypervisors like KVM/Xen? The underlying linux should not be an issue, if there was so possibility to add the needed tools/drivers.
Thank you and best wishes
KPS
Hi!
As you are more and more push your edge-computing devices:
Is there any chance to get IC2 for KVM?
also many persons want to use proxmox acutally.
Hi.
Yes… Fusionhub works nice under PROXMOX.
thats nice Marcelo,
do you know if ICVA (private InControl2) is also running with Proxmox?
Hi, Dennis…
No. I don’t know about ICVA. Never try it.
Any news about that?
I just found hints in this post:
…but the docs are still not showing KVM/proxmox. As the EC-devices are using KVM, that should not be a big thing.
