I would like to be able to have a column like you have for WAN that shows if it’s connected via hardwire or cellular, but for just cellular status. If a device is online with a wired WAN connection and the cellular is currently having issues and not connecting, such as modem stuck in a “resetting” state etc, there is no easy way to see this data without going into that device. I would like to easily be able to see the cellular status as connected or not via the main dashboard.
I like this. Being able to see the different cellular statuses from the device menus would be very helpful to see if the connection is either resetting, down, in Cold standby when it should be up or vice versa.
This is a really good idea and shouldn’t be too hard I believe! +1 from us!
+1
This would be a great addition to the reporting inside InControl2, and I see it as being a proactive way for MSPs and resellers to get in front of issues if they notice a problem.
@Michael can we get this added?
+1 From here
Same with devices stuck with “Connecting” or other status than Connected.
