Dear Peplink,
I am planning to purchase your device Peplink as I have had requirement for my organization setup. I have 2g & 3g CDMA data cards along with 3g GSM data cards and I am planning to aggregate all the bandwidth of my links like as I have 2 data cards along with 7.2 kbps after aggregate the bandwidth that would be about 14.4 (7.2+7.2) Mbps so please let me know do you have such device which can full fill my requirement as peplink have the same features ?
Urgently, I need this device
***Regards **
Abhishek Kumar
Technical Trainer (IT)
You could use the following devices depending on your requirements:
MAX-700 - Offers 4x USB ports to connect your modems.
MAX-HD2 - Offers 2 integrated modems and 1x USB port for externel modem.
A feature comparison between models is available here:
http://www.peplink.com/products/max-cellular-router/pepwave-max-700-hd2-comparison/
With a single unit you can do load balancing which will spreadout network traffic on a per connectionb basis over all available connections.
With multiple Peplink devices such as a Max700 and Peplink Balance and a SpeedFusion VPN tunnel between them you can acheive bonding on a per packet basis over all available connections.
The following link gives an overview of SpeedFusion bonding: http://www.peplink.com/technology/speedfusion-bonding-technology/
-Jonan
