I have 2 line Fiber i need Balance
Hi
i have 2 line WAN Fiber 200 Mbps + 200 Mbps
i need Throughput 400 Mbps
[RIGHT]What is the most appropriate choice peplink model ?
[/RIGHT]
for Example : show PIC attachments
[RIGHT]last question :
What is the country of manufacture of the devices
[/RIGHT]
What is the country of manufacture of the devices peplink ? made in ???
Depending on the number of users, you can consider Balance One if it’s below 60, or Balance 305 and above if more than 60 users.
users for what ?
What is the intended users?
do you mean DHCP IP address ?
i need only 1 IP from Peplink Balance One
Is this enough ?
thanks
Users are referring those behind the Peplink.
If this is for home use then Balance One should suffice.
Lock at attach
is Peplink Balance One come from made in China ??
It is manufactured in Taiwan. Thanks
Hi Kaaser9,
Model sizing not referring to router throughout only and it’s also include other considerations. For more information, please refer to the URL below:
Thank You
