The 3G HUAWEI E3131 is working fine with Blance 310 and on my PC so no connection problems, but on my Balance 20 on the dashboard Status: connecting and does not go further. Please advise.
Best regards.
Best regards.
I would open a support ticket with the technical team. Otherwise if the device is in warranty I would recommend upgrading to 6.1 firmware as this should fix the issue. If not open a support ticket here and a member of the team will take care of you.
http://cs.peplink.com/contact/support/
Balance 20 has 6.1 firmware ?
Correct,
It is the most recent firmware. Here is the upgrade guide to get to 6.1. http://www.peplink.com/knowledgebase/firmware-6-1-upgrade-guide/
So am running 5.x and still under warranty is it free of charge for me ?
Thanks it solved my problem
