So I tried to understand the manual, watched the video on youtube posted by the 3G store. Enabled the PPTP server on my Peplink SoHo and created a user account.
Now how do I connect to this?
I would like to securely access some files on my Mac. And also access the internet via the VPN tunnel.
When I try to create a VPN account on iOS7 I am asked for a Server… Other than some wild guesses I have no idea what to enter here
My ISP is Comcast cable with a dynamic IP address (do I need to use a service like Dyns.com ?)
Once done depending on if you are on a Mac or PC you will start open/start a vpn connection. It will ask for remote IP (Public or hostname of the SOHO) then you will fill in the username/password (created on SOHO) on the client vpn.
I just went to the Dyndns website to sign-up for an account but am not sure what options to choose.
Right now I want to test accessing the Pep SoHo via VPN/PPTP and access my data and browse the internet.
Don’t want to change anything on my current DNS and MX records.
In the near future I might want to start experimenting with a Mac Mini Server. And I do have some other domain names available if needed.
You can configure the hostname to anything you would like. Then for ip address you will use the current WAN IP that is displayed on the SOHO dashboard for the applicable WAN. Once created you will then click on details on the applicable WAN in the SOHO then scroll to the bottom of the page and enable dyndns and input the required information to tie together the dyndns host name to the selected SOHO WAN.
This time I have installed a SoHo at the clients location with the goal to gain remote access to some local files using the PePlink VPN.
ISP is comcast with a static IP but cant figure out how to make this work.
Since you have static IP (I assume this is static public IP), you just need to enter remote IP (Public IP of SOHO) then you will fill in the username/password (created on SOHO) on the client vpn.
So the remote address of your VPN client should point to 2.2.2.2 (for example above) and the login credential should match with the account in PPTP server in Soho.
Thanks for your reply, but can you please tell me where I can find this “box” to enter the static IP address?
I looked all over the UI but cant find it. Surely its right under my nose but somehow I don’t see it…
