How to use both SIM card slots Simultaneously
Hi
i insert 2 sim card in 2 slots of Peplink 30 LTE
i want using of two sim card internet in a time .
How to this ?
Hi , is not possible on Balance 30LTE, you can use or sim A or Sim B.
by default the Sim A is primary and Sim B is a Backup.
Ciao
Antonio
Just to add to @asimula’s comment, if you want to have 2 active SIM-cards, you will atleast need a Pepwave MAX Transit DUO.
The Pepwave MAX Transit DUO has 2 cellular modems, allowing you to have 2 active SIM-cards at the same time.
Why does the device come with 2 slots if the sims can’t work at the same time ?
Does the backup sim come into play when the first one has no signal ?
I have a Peplink B one 5G…
Hi…
As explain in another post…
B-ONE, BR1minihw3, BR1pro5G are single LTE modem device. So they have two slots for sim card one as principal and other as standby. This device are good for situations where are not necessary to have speedfusion agregation using SIM CARD, because the main goal of this device is to work with WAN and a secondary option do a redundant service, using SIM card.
Please… contact your reseller. I believe that they can understand what you need and better see a device that help you.
Thank you very much for the explanation but I still don’t understand what is the function of the second SIM.
When the mobile network used by the first SIM fails, or you move out of coverage, or you have a SIM with a limited amount of data which runs out, the modem can change SIMs to a different provider to keep you connected.
