I’m planning to buy a Peplink 20 or 30 but I’m worried that some resellers are still showing on their web a throughput of 30mbit/s. How can I check for sure that I’m going to get the 100mbit/s revision?
It’s easy. All new Peplink Balance 20 / 30 with the metallic casing is capable of achieving this speed with the latest optimized software. So just make sure it looks the same as the one we have now posted on the website, you will get the 100M capable hardware.
We have phase out the old model for more than a year and i think you will not find it from the resellers.
Regards,
Matthew
Wonderful. Thanks. I’m on my way to pick it up…
