How to setup to use WAN(Starlink), WiFI and cellular (in that order)
Using a peplink br1 max pro 5G, I’ll be streaming in a venue that has great wifi upload speed (>50 kbps) and I’d like to have a hotfail or better option to use them in that order. I set up things like the description in the excellent video “how to backup starlink with 5g cellular for improved reliability.” When i try to setup the priority table in the router dashboard, it won’t let me set wifi above cellular. I’m new to this, so any comments appreciated.
Hi! I assume currently you have set:
Priority 1 - Starlink
Priority 2 - Cellular, Wi-fi WAN
If this is the case - you can just move the Cellular connection down to priority 3.
Also I see in the video (from around 08:00) the author explains how to set up SpeedFusion Connect, if you’ve set this up in your device aswell - then all three interfaces (Starlink, Cellular and Wi-Fi) can should left as priority 1. With their actual priorities configured in the SpeedFusion Connect settings (in the video this is shown at around 10:44).
Though if you’re not using SpeedFusion Connect - then only the first part of what I said applies.
