How to Setup DHCP Ranges in InTouch2
I have spent most of my day trying to figure this out. I think this is crazy I can disable InControl2 management and Web Admin into the router and do it so easy but I can’t do it from InControl.
What a royal PAIN.
I have tried everything. I just don’t want to turn of InControl for this one feature when I need the other features.
What is the trick her. PLEASE before I go insane
At the Group level, choose Settings, Device IP Settings. Here you can put the serial numbers of each unit and then set the LAN as well as the DHCP settings. It will be enforced here and no local changes can be made. It will look like this:
SN, LAN_NETWORK_LIST, DHCP_SERVER, DHCP_SERVER_LEASE, DHCP_SERVER_NETMASK, DHCP_SERVER_POOL_START, DHCP_SERVER_POOL_END, DHCP_LOG_ENABLE
xxxx-yyyy-zzzz, 172.16.0.1/24, enable, 86400, 255.255.255.0, 172.16.0.10, 172.16.0.100, no
Where can I check and see if it took ?
Not sure I have this right.
I have (2) VLANs on each router, how would I do that ? Does this look right ?
SN, LAN_NETWORK_LIST, DHCP_SERVER, DHCP_SERVER_LEASE, DHCP_SERVER_NETMASK, DHCP_SERVER_POOL_START, DHCP_SERVER_POOL_END, DHCP_LOG_ENABLE, LANn_VLAN_ID
SN, 192.150.0.1/16, enable, 86400, 255.255.0.0, 192.150.10.10, 192.150.10.100, no, 10
SN, 192.151.0.1/16, enable, 86400, 255.255.0.0, 192.151.10.10, 192.151.10.100, no, 20
SN, 192.150.0.1/16, enable, 86400, 255.255.0.0, 192.150.11.10, 192.150.11.100, no, 10
SN, 192.151.0.1/16, enable, 86400, 255.255.0.0, 192.151.21.10, 192.151.21.100, no, 20
