:rolleyes:i have 2 broad band connection for my workstation pc(AIRTEL&RELIANCE)…workstation 1 pc having 2 ip’s((A1)192.168.–.-- & (B1) 192.168.-.-)
workstation 2 pc having 2 ip’s((A2)192.168.–.-- & (B2) 192.168.-.-)
i have 2 switches(24 port procurve switch)
I WANT CONNECT these 2 network’s using switch or router but I need if IP A1 and IP B2 fails na that time A2 and B1 want to COMMUNICATE AUTOMATICALLY WITHOUT TIME DELAY
WHAT YOU SUGGEST…PLS HELP ME
BY
PONSIVA
+917418146780
Let me move this to the Peplink Balance forum. Folks there can definitely give you a hand on this.
If you are maintaining two separate networks just because of two ISP:- Simply place a balance device, terminate both your ISPs on WAN and connect workstations to LAN.
ISPs can be configured to work simultaneously or one as a backup to other.
as you wish…Any specific reason for maintaining two networks!!!
ONLY FOR REDUNDANCY CONCEPT…
TWO WORK STATION PC’S WANT TO COMMUNICATE WITH EACH OTHER…IN THIS CONCEPT
WORKSTATION 1(WS1)=A1 AND B1 & WORKSTATION 2(WS2)=A2 AND B2
INCASE A1 NETWORK FAIL FROM WS1 AND B2 FAIL FROM WS2,THAT TIME A2&B1 WANT TO COMMUNICATE AUTOMATICALLY WITHOUT TIME DELAY
WHAT’S YOU SUGGEST?
PLS GIVE SOME TIPS TO SATISFIES THE CONDITION
Refer following URL: http://www.peplink.com/index.php?view=faq&id=46&path=29
