Hi all,
I’m relatively new to this device. I upgraded my Pepwave MAX BR1 Mini to FW=8.1.0 build 4941.
How can I get to the interface to set up static-MAC bound DHCP addresses?
I thought I saw it there in the older 7.x.x firmware.
thanks,
-ted
Hi all,
thanks,
-ted
Well, to answer my own question. It’s in Network->Network Settings. Then clicked on the “Untagged LAN” network link…
The UM at
https://download.peplink.com/manual/pepwave_max_surf_v6.1.2_user_manual.pdf (pgs ~34 to 38), not quite clear about this; the UI maybe not super-intuitive compared to using some other products I’ve used in the past, just my 0.02 cents.
-t
If you use VLANs, you will see that each VLAN has its own set of DHCP reservations.
