Is there a way to see the health of a connection? I was running some speed tests that are not as fast as normal, download speed was fine but upload speed was reduced. When looking at the realtime bandwidth usage I could see that only one of the connections was being used in the upload speed test. Is there a way I can get more information on the connections to see why one connection is not being used for uploading?
You can view the health of a connection by going to http://<Your device’s IP>/cgi-bin/MANGA/support.cgi
This will show you some more detailed information on a packet level for each WAN.
You will want to take a look at how your Outbound Policy rules are setup (Network>Outbound Policy). This is where you control how you would like traffic to be routed out. To have technical support take a closer look at this I would open a support ticket here: http://cs.peplink.com/contact/support/
