I am trying to download the docker essential package. But it seems like having issues. There is less materials regarding to it hence need some assistance on it.
- System: Docker “essential package” installation started
- System: Docker “essential package” installation interrupted
- System: Docker “essential package” installation failed (download failed:4)
              Can you provide screenshot that shows the reported issue?
              Please format the Docker at System > Storage Manager then download the Essential Package again at Network > Docker.
Hope this helps.
              I already done it, but the issue still persisted. Do I need to configure anything before able to use it?
              @Nazri_Mazlan, maybe you can submit a support ticket here for the team to take a closer look?
Do quote this thread so our support team could pick up the background information when processing the ticket.
              After investigate, we found that WAN is blocking the download and this cause the docker essential package download failed. Issue resolved now ^^
