I’ve used the free version of FusionHub, and now I see it wil expire soon.
My question, is it possible to renew the license without remove FusionHub and added it gain ? and how to do that ?
King regards,
King regards,
You can purchase the InControl2 subscription via Peplink estore.
Browse to https://estore.peplink.com/
Put your SN under search
It should return you the search results for the available subscription and you can purchase it from there.
Thanks a lot @sitloongs for the quick answer, so that means I can use the free version again ? without remove it and add it again ?
The free FusionHub Solo license only come with 1 year free IC2 access, after 1 year if you need to manage the device via IC2, you need to purchase the IC2 subscription in order for you to continue managing the device via IC2.
To answer you question :
Yes, if you purchase the IC2 subscription for the free FusionHub Solo, you can continue managing the device using the IC2.
