The Balance 310 8.1.0 and 8.0.0 firmware CPU Load stays at 100%, even after a reboot.
I suspect the 1000+ entry long DHCP client list.
I wish to purge/clear the list entries that are due to expire. Reducing the LAN > DMZ > DHCP Server > Lease Time to only 1 day doesn’t purge the list. Neither helps a reboot.
How to manually purge/clear/clean/reset the DHCP client list (or reduce its number of entries)?
Hi. Disable DHCP and save. Re-enable DHCP and save. That’ll clear the DHCP pool.
Note that if you have multiple VLANs/network segments you’ll have to do this procedure for each one.
Thanks for the to disable, save, and re-enable the DHCP pool. In this case it didn’t clear the DHCP pool. Support did clear the pool via remote assistance.
Interesting. We’ve never needed assistance in that regard. Well, glad it worked out! I wonder if there was a regression in the code.
I do find this annoying, as disabling/enabling loses all the static bindings. It would be 100% preferred if the leases were taken out of the pool when they expire like they should be. Is there any real benefit to consuming an entry in the pool after they have expired?
I wan to bring attention to this problem
DHCP flush indeed would be handy.
Today I have problem with few Apple devices with randomized MAC. It used up 250 addresses in a few hours.
Disable DHCP and enable didn’t flush pool. Changing scope didn’t help. I extended DHCP range to /23 and lover lease time to 2 hours. Probably now will fine.
Still simple Flush command would be really handy.
Hello @luka_madunic
We are supporting a client through a Peplink ticket, open for a very similar issue: 25120712, “IP addresses not being released into DHCP pool after lease time has expired”.
The Peplink team needs more examples of the issue to understand the impact better and isolate the cause so that they can engineer a solution into future firmware releases.
Please open a new Peplink Support Ticket (Help & Support Hub | Peplink). Document everything you can in the ticket, including screen captures, configuration notes on the DHCP setup(s), firmware version(s) and the Diagnostic File(s) from the router(s) status page, and add it all to the ticket. Once you have created the new ticket, please note the ticket number here in this forum thread.
Have a good week,
Marcus
