I have an authentication server which has 2 network cards for WiFI hot-spot users in front of the 710 router. Currently I’m doing NAT in the server with inside address of 172.16.0.2, outside address of 10.0.0.2. The 710 then has a 10.0.0.1 address on the LAN port and a 71.x.x.x address on the outside among others. I was told that if I turn off the NAT function in the software that the server then turns into a layer 3 router. However, I would have to have the 710 router set a return address to point to the inside interface of the router. If I had a Cisco router, the command would be
172.16.0.2, 255.255.255.0, 10.0.0.1
How do I do this in the 710 router?
Rory Conaway
www.triadwireless.net
