how can we assign public IP from the data center to speedfusion remote gateway that doesnt have static IP?
That depends. What do you want to achieve specifically? Can you draw a quick sketch?
Hi leezy,
Have a look in that post
https://forum.peplink.com/t/external-ip-behind-speedfusion/32338
After that I’ve solved it.
Regards
Dennis
i cant seems to access that link. it seems to be missing or it is private.
any luck on your side?
ups, you’re right.
Where are you located? I think for that configuration a peplink-partner should assist you.
im also a peplink partner, it seems that alot of things are not allow to access from my side.
who should i contact?
@leezy, I suggest getting help from your point of purchase - local Peplink distributor. They should able to help.
Thanks.
