Hi All,
Any method that we can open / read the config file of peplink by using any tools or method? I tried to open with notepad but It unable to show the readable info.
Thank you.
Regards,
Edwin
Hi All,
Thank you.
Regards,
Edwin
Yes that would be nice. I would also like to read these files.
@fool1988 and @Ballistic
You won’t able to read the config file because it’s not in the plain text format.
Please load the config info a device without applying the settings and this should allow you to view the settings via WebUI. You can discard the config after that without applying it to your device.
