In my network, some users constantly download data causing congestion, difficult to access the network with other users. So how to limit the bandwidth of each IP on the peplink balance 310? Thanks
Sure. The following is for firmware 7. Could be a bit different on prior versions.
Network > Bandwidth Control > Individual Bandwidth Limit. You’ll first need to define user groups on the section just above. You can put everyone in the same group if desired.
Thanks , but i am using firmware 6.1.2, it doesn’t have bandwidth control , I checked for firmware and no update available . Sr about my english.
You can check the latest firmware here
Thank you .
