Using Virtual Machine Manager to create a virtual machine with USB storage
Virtual Machine Manager (can be downloaded here) is a desktop user interface for managing KVM virtual machines through libvirt. It presents a summary view of running domains, their live performance & resource utilization statistics. Wizards enable the creation of new domains and the configuration & adjustment of a domain’s resource allocation & virtual hardware.
The wizard provides the following methods to install the operating system in the new virtual machine:
- Local install media (ISO image or CDROM)
- Network Install (HTTP, FTP, or NFS)
- Network Boot (PXE)
- Import existing disk image
Upload ISO or disk image to the MBX:
To upload an ISO or disk image to the MBX, navigate to “Advanced” > “KVM”, and open the file manager from the link “Click here to open file manager”.
Below are the steps for creating a Virtual Machine from an ISO image:
Open Virtual Machine Manager on the local PC (eg. Linux OS such as Ubuntu, Fedora, etc). Select “File → Add Connection…” and a dialog will appear. Configure the settings as below and click “Connect” to access the Peplink router KVM Console. The Username is the Web Admin / Username, and the Hostname could be hostname or the IP of the Peplink device:
Input username and password for authentication. These are the same credentials as the device’s Web Admin login credentials, eg. User ID: root, Password: Abc@123456.
After establishing a connection, a summary view of the VMs that are installed on the device will be displayed, as shown below. You can also start or shutdown any VM while in this view.
Go to “File → New Virtual Machine” in the menu bar and the dialog below will appear. Select “Local install media (ISO image or CDROM)” and click “Forward”.
Browse and select the uploaded ISO image and click “Forward”.
Specify the RAM size and the number of CPUs to be allocated to the VM and click “Forward”.
Specify the storage size for the VM and click “Forward”.
Specify the name of the VM. Ensure that the “Customize configuration before install” checkbox is checked and specify “br0” in the “Bridge name” as shown below. Click “Finish”.
A VM configuration dialog will appear as shown below.
Modify the hardware configuration:
- Select “Copy host CPU configuration” under “CPUs” as shown below.
- Select “Display VNC”, and follow the settings as shown below.
Click “Add Hardware” to add “Video VGA”. Remove “Tablet”. The final hardware configuration is shown below. Click “Begin Installation” to start the installation.
Open a VNC viewer and connect to the device as shown below:
A console will appear. Complete the installation here.
When the installation is completed, the newly created VM will appear in the summary view as shown below.:
In order to add USB storage to the Virtual Machine:
Insert the formatted USB disk to the USB1 port on the MBX.
Open the virtual hardware details dialog:
To add the USB storage, click “Add Hardware”. Then, select “Storage” from the column on the left. Click on “Select or create custom storage” and then the “Manage…” button.
In the left-hand column, select the storage pool called “USBStorage1-1” for the USB disk. In the right-hand column, select the desired volume and click “Choose Volume”. If there is no volume in the disk, you can click the “+” button to create one.
Change “Bus type” to USB as shown below and click the “Finish” button.
“USB Disk 1” has been created for the virtual machine:
Power on the virtual machine and “/dev/sda” is now ready for use.
NOTE:
This feature is only applicable to higher-end models with more powerful CPUs and larger storages, e.g. MFA500, MFA750, and X-series routers with storage options.
This is officially supported on Firmware 8.1.0 or higher…
